- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to create a dynamic block where I have (2) shapes that it automatically change to as you stretch the linear dimension. Starting out I would like it to be a small 55' rectangle and then after you hit 115' it changes to that, continuing to re-evaluate the array every 55'.
I created a linear stretch with an array and a lookup table/visibility parameter on my first go, but no matter what I try I can't seem to get it to evaluate it properly. Do I have to do a double look up for this to wok correctly or is there an array trick where I can set the linear constraint to a list with 55' and 115'?
I attached a base file I have been testing on as well as a screenshot. I can get it to work as an array, but I can't get it to update with the new shape.
HALP!
Thanks.
