- Mute
- Permalink
- Report
Tried to make a fridge block with a built in label that rotates when the block rotates so that it always legible. To do this I added one main rotate parameter for the entire fridge set to 90 deg increments, and then three separate rotates on the text as chain actions also set to 90 deg increments each. The fridge is also stretchable in width and depth.
the block works, however there is an odd glitch that whenever one of the stretch grips is used in the Y direction (doesn't matter which grip, when it is rotated, whichever is along Y is the one that glitches) the rotation angle changes and is no longer set to 90, 180, 270 etc. I attached the block for you to see.
Is there a way to stop this from happening? Is the chain action causing this somehow? Any ideas to resolve?
Thanks!
