Dynamic Block Stretch Dimension
I created a dynamic block for a door. It works great on my computer, but when someone else opens the file on their computer. The dimensions do not show on theirs so they do not know what size they are stretching to ( I have it set at an incremental stretch from 3' to 4'). Does anyone what I can do to change this?
oswaldodcb
Hello @Anonymous and Welcome to the AutoCAD community!
I wonder if with dimensions you mean the properties of the block? Or a dimension that you have associated with the block?
If you can load your block to help you better,
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
When I wrote this post, I meant to say temporary dimensions on the door. What I found out it that their dynamic input visibility was not at the same level as mine. Using DYNMODE and changing it from 0 to 2, the temporary dimensions showed up on the door.
oswaldodcb
I understand, I recommend that to realize when a variable is modified you can activate the notifications from SYSVARMONITOR, so you will know of any changes in the variables of a file,
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
I hope it will be useful,
Oswaldo Caballero
LinkedIn
