Dynamic block parametric actions damaged when moving up attributes in Block attribute manager
- Mute
- Permalink
- Report
I m using dynamic blocks to set some actions to Main attributes
I need the each Main attribute to follow the slope and position of each related line.
My major problem is that when I want to change the sort of this Main attributes in the block attribute editor(move up or down) ,the parametric actions are damaged.
Also I have another minor problem, is that I have another secondary attributes that are set to read values from the main attributes when I fill the main manually .
but I need only the main to be visible when I use : ATTEDIT
while the secondary not visible.
I tries to change it to constant but it does not read from the main after changed and recreate.
I attached an example.
