Dynamic block of Rectangle with slots - almost works
Greetings,
I have used AutoCad for years but just started using Dynamic blocks. I created a DIN Rail block which worked fine, then decided to try adding the slots as an array, which almost works. What I would like to do is shown in the Non-Dynamic block; "Din Rail Desired Display". The way it really works is shown in the uploaded block: "DIN_Rail_Arrayed".
So in short I would like to cut off any slot that would really be cut off when you saw / stretch the DIN Rail to the size desired. Maybe I am asking too much?
Doug
Libbya
Libbya,
Thanks for the reply. I will take a look at your link and see if my tiny little brain understands what they did.
Doug
