Dynamic block Nuts for bolts
I am making a dynamic block for nuts using this list of dimensions
https://www.fullerfasteners.com/tech/din-934-specifications/
I have made a front view and side view,  and used the linear dimensions for the dimensions indicated in the list photo's, but i run in a couple of issues:
-When i change the dimensions (s and e) in my front view the hexagon doesnt stay a hexagon and changes in a weird shape.
-The side view had the same problem as my front view, when i change the dimensions (e and m) the shape goes weird and doesnt look like a nut anymore.
-The blue circle in the front view i know what the dimension is according to the list on the site im using, but i cant find any information about the internal circle in it. I know this circle indicates the thread used in the nut, does anyone know where i can find the information about this.
If you can help me with this problems i appreciate it
ojuris
Why you try to stretch hexagon? It always must be hexagon. Remove stretch actions and add scale action to "e" same way as to "s" for circle
And I think size e is not required. If you have regular hexagonal and change size of it (s) then you get size "e" geometrically and for different s it will be different. In table I see for s = 5.5 and 6  e = 6.01. It is not possible geometrically.
