- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I looked at a solution that resulted from using ATTSYNC and tried that. It did not fix my problem.
The following three pictures show the problem where the attribute changes its position when the block is placed.
This is how the block appears in the drawing with display option "Title NTS" selected.
Notice how near the title text is to the underline (which is an an actual line).
This is how the block appears in the block editor with display option "Title NTS" selected.
Notice how the title text is further away from the underline.
This is what is left in the drawing when the placed block is exploded.
Notice that the attribute position is now moved up matching the position of the block definition.
The following three pictures show the problem where attributes that should be hidden in this display state are not hidden.
This is how the block appears in the drawing with display option "Title Only NTS" selected.
Notice how bubble attributes remain displayed while the circle and line of the bubble are not displayed
This is how the block appears in the block editor with display option "Title Only NTS" selected.
Notice how bubble attributes are hidden for the definition of the "Title Only NTS" display state.
Notice how bubble attributes are not included as a part of the exploded "Title Only NTS" display state.
The bubble attributes are on a unique layer as well. How can these problems be fixed?
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
8.6.52.0 AutoCAD Architecture 2024
