Dynamic block for Section Lines
I have a dynamic block of a section line with single line taken from this forum. I need a similar type of dynamic block with multiple lines in Section line which can be stretched at all the edges of the lines. Also Section line can be flipped in either directions. Is it possible to create (See attachment).
timothy_crouse
Here is an updated dynamic door block.
-Tim C.
Hi
I have posted the query for Section lines. I think the attachment seems to be for doors.
Can you have a look again.
timothy_crouse
Here is a starter for you.
The technique required to create this was:
-Linear Streatch
-Point Move
-Attributes Locked in properties
I had no idea on your scaling requirement, copied what you posted, I am guessing it is metric?...
Hope that gets you pointed in the right direction.
-Tim
Thanks Tim !  It looks great ....
