Dynamic Blocks Forum
Dynamic Block Double Door 45 Degree Swing - Problem
7 REPLIES 7
Message 1 of 8
1759 Views, 7 Replies
I'mm creating a dynamic block of double doors with 45 dgree swings. I can get the left leaf to size correctly when I use the stretch action but the right leaf doesn't work. Can anyone help me please?
Bernie
7 REPLIES 7
Message 2 of 8
Libbya
Here you go.
Message 3 of 8
in reply to: Libbya
Fantastic! Thank you very much!!!
Message 4 of 8
Libbya
You're welcome.
Message 5 of 8
in reply to: Libbya
Hello
I have a problem with my double door Dynamic Block & Its driving me crazy ! The single doors I've created work perfectly fine.
The Arcs of the door openings move away from the door as I scale, I've tried everything, why??
Message 6 of 8
ojuris
hi!
try that one
Message 7 of 8
Libbya
Tired everything?  That's funny.
They move away from your door because the basepoint of the scale is not at the center of the arc.  There's nothing wrong with the block Ojuris posted but the one I attached is a fair amount simpler.  I changed the distance multiplier on your angled stretch actions to 0.5 as they should be - otherwise the total door width is larger than the opening when the opening is made larger.  I changed the scale action to independent and moved its base point to the left arc center.  I eliminated the straight stretch and added the jamb to the move action.
Message 8 of 8
in reply to: Libbya
Hi Libbya,
Would you possibly know how to adapt the attached dynamic block - to add a range of opening angles for the door swings. I would like to add:
0  degress (closed)
30 degress
45 degress
90 degress
Many thanks in advance.
Eoin
AutoCAD Inside the Factory
