dynamic block convert to static
Hi
Please anyone can sugest a way to convert Dynamic block to simple static block, the reason is when we importing to sketchup all the dynamic block disapear.
Regards
Pointdump
K,
Did you try deleting the parameters and actions in the Block Editor? That should leave you with an "ordinary" block.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Hi Dav,
Thanks for your solution,  that did not work, but I solved the problem with another way, I had insert the AutoCad file in Revit and export it AutoCad again, that solved the problem, sorry for the delayed reply.
Thanks again.
