Dynamic block Contraints
vboire9DBSV
vboire9DBSV
What constraints or group of constraints would I require in order to be able to move the red line while always being connected to the 2 green lines? And have the green lines keep their locations. File attached. constraints.png
Libbya
Short answer is 'none'.  Using constraints to accomplish that would be the hard and problematic way to do it, IMO.
vboire9DBSV
Any suggestions?
Libbya
Well, I was trying to record a screencast of the 'easy' way to do it, but something is not right with your file.  The angle offset for move/stretch angles are messed up.  They seem to default to 90 instead of 0 as they should and when set to 0 they behave incorrectly.  I did a recover on the file and it showed errors.  I'll make a similar screencast from a fresh file and hopefully you can apply the technique as needed.  Just a minute.
Libbya
I add a move action that has 0 angle offset and 1 for distance multiplier and move the line.  I then add a stretch action to each end of the line.  I adjust the angle offset so the stretch is perpendicular to the parameter movement.  I offset the line 1 unit and use quickcalc to get the adjusted stretch distance per 1 unit of parameter movement.  Hope that helps and makes sense.  See screencast.
vboire9DBSV
Thank you. My mind was convinced it should be a constraints function. Very much appreciated.
