Dynamic block bulk property edit
So I saw that Lee Mac has a lisp that edits all blocks in a dwg.s attributes simultaneously.
I have a lot of dynamic blocks in a drawing that require most of the same properties, but while selecting and editing them I get about a second delay per block per edit...
Is there a lisp that edits all properties of all dynamic blocks in a dwg. simultaneously??
Libbya
I often use qselect to select all of the blocks of a given name (or similar) and then use the properties palette to adjust a given parameter.
Either your computer is very slow or you have an issue with the software.  I can select many dynamic blocks without any perceptible delay unless they are VERY complicated (e.g multiple lookups, double lookups, visibility states, etc...).
yes they are very complex
Libbya
How about posting an example file and I can tell you if it hangs at all for me?
