dynamic block/attribute/field definition from block properties table/Excel
- Mute
- Permalink
- Report
I have created a single dynamic block with multiple attributes. The attrib-values are assigned from a combination of user input, system variable and fields associated with a properties table. Now I want to define several more dyn-blocks using the same method. I tried making a block of the attribute definitions (to insert and explode) in the new block definition. I have trouble getting the definitions to update in the secondary dynamic blocks. From what I have read it sounds like a block definition within a block definition problem but I have not figured it out (obviously).
The values of the block properties table are assigned using copy and paste from and excel sheet (created in QuickBooks). The data format is "general" and appears to have no complication with the problem.
To those that see where I am heading with this....I plan to write an excel file with DATAEXTRACTION and then dump it back inot Quickbooks as well as create a BOM schedule in the drawing file. To those that have already tried or accomplished this...can you give me any heads-up on problems????
