Dynamic block - Array
Hello
I am working with dynamic blocks.
I want objects to be arrayed as I stretch an object - see the attached PDF for the start / finish illustrations.
I want the user to set the array distance - so the objects are arrayed at a chosen distance - is this possible?
The second option would be to have the user set the distance "distance set by user" by using a stretch action - then to have the array use this distance for the array offsets by somehow linking them. Is this possible?
My ability with dynamic blocks is limited and pretty much self taught so any assistance would be greatly appreciated.
I am using AutoCAD LT 2016
Imui
hi,
it's doable, but in LT2016 the normal array command can also do that.
Imui
Thanks for your reply, could you give me some guidance with regard to "its doable" please - in other words how is it doable?
I don't want to use the normal array command I want to use the dynamic block array action.
Imui
Sorry, i don't know of any way to "dinamicaly" adjust the value of the array action.
But, as i said, give array a try.
thierry_69
An example of dynamic bloc according to your pdf file
Thierry
thierry_69
Thank you very much for taking time out to do this, appreciate it.
Do you know of a way whereby the user of the block can set the array distance?
Libbya
It is not possible to dynamically change the array column offset.  If the number of arrayed objects is a relatively small number you can make a block where you can choose the number of objects and they will be spaced evenly.  Another option would be to make a block with intervals to the column offset and a new visibility/array for each interval. See examples of both in the attached file.
