Dynamic Block Array - Stretch to Fit Non-Incremental Wall Distances for Brick Placement
k.spanoudakisCPQW3
Message 1 of 9
k.spanoudakisCPQW3
Context: I am working on creating a dynamic block for a brick array.
The goal is to efficiently fill a space between walls with bricks, even when the distance between the walls is not an exact multiple of the brick length.
When the distance between the walls is not an exact multiple of the brick length, the array does not fit perfectly. There is a remaining space that does not accommodate a full brick.
I want to create a dynamic block that will fill the space with full bricks and then stretch* the last brick to fill the remaining space.
As shown, the current array setup with fixed-length bricks and the desired outcome where the last brick is stretched to fit the remaining space.
*The last brick is only the outline+hatch, without the inner parts.
Replies (8)
Message 2 of 9
MMcCall402
Please post the block you have so we don't have to start from scratch.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 3 of 9
j.palmeL29YX
Attached an example for a brick dimension 250x100 and space between bricks of 20.
Surely you must adjust the dimensions to your needs.
Jürgen Palme
Message 4 of 9
k.spanoudakisCPQW3
Hi, thanks you for the solution.
Opening to block to see how exactly it works, I can see the geometry and the dimension, but not the constraints.
After selecting everything, then I am able to also see everything. Still don't know how to select and edit constraints though...
Screenshots for reference.
Message 5 of 9
j.palmeL29YX
The short answer: Activate the Parametric Tab - so you can see and edit all constraints and dimensions.
Some more detailed explanation:
Jürgen Palme
Message 6 of 9
UKTC-COORD
Community Visitor
Community Visitor
Is it possible to do this with more complicated shapes? I'm trying to achieve a similar outcome with a chain, stretching in increments just doesn't look right
Message 7 of 9
j.palmeL29YX
It depends on what your chain looks like and what you want to achieve.
Post a dwg file of your chain please.
Jürgen Palme
Message 8 of 9
UKTC-COORD
Community Visitor
Community Visitor
I've made a dynamic block for a chain block and a pull lift (lever hoist) and attached one that someone else has made. I'd like to be able to adjust the length of the chain to any length smoothly whilst keeping the chain right. Your brick solution is the closest thing I've seen without using increments but with much less complicated geometry.
Any help would really be appreciated.
Message 9 of 9
j.palmeL29YX
For such a geometry, I cannot suggest a solution that does not require any increments at all. But you can break the geometry into small "slices" (reduce the value of the increment) and you will get a much smoother behavior. Choose the number of slices (here 15) until you get an acceptable approximation. This can be a lot of work, you have to decide if the result is worth the effort.
Atttached an example
Jürgen Palme
