dynamic array: count every piece as 1.
Message 1 of 13
hello,
i want to have an array dynamic block, but i also want them to count each piece from the array as 1 object and not as 1 dynamic block in a data extraction.
who can help me?
kend regards
Replies (12)
Message 2 of 13
MMcCall402
Some ideas:
If the item(s) being arrayed in the dynamic block is itself a block, then you can run a data extraction on that internal block for a 'count' of those blocks and it will count all instances of that block, both inside the dynamic block array and if the block is inserted as a single block.
If the item(s) being arrayed are not a block, you can have the date extraction pull the linear parameter value that controls the array, table the values, add a column with a formula to divide that value by the array distance, then total the column.    Or, you could insert an attribute into the block with a field set to access the value of the linear parameter, divide it by the array distance, then have the data extraction pull that block attribute. (you can make that attribute not visible)
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
Message 3 of 13
In attachment I have put the dwg of the dynamic blocks with an array.
It's for making a light line, so every piece I need to count as 1 if a make the array.
Kind regards,
Kevin.
Message 4 of 13
MMcCall402
Try attachment again.
Mark Mccall
CAD Mangler
Linkedin
Message 5 of 13
i have the file in attachment
Message 6 of 13
MMcCall402
I see now.
Add a new attribute for calculating the array. We'll insert a field as the default value for this attribute to get the value of linear parameter Distance1 and then divide it by the length of the array repeat distance to derive the number of items in the array.
Add the new attribute.
In the cell for the Default value right-click and choose Insert Field.
Choose BlockPlaceholder in the Field Names column, Distance1 as the Block reference property, Format as Decimal, Precision 0, then go to the Additional Format and set the conversion factor to 1/1500. (this conversion will be different for each block)
Save the block and run Attsync to resync any insertions of the block with the new block definition.
Now run the data extraction to collect this attribute of the block(s)
Mark Mccall
CAD Mangler
Linkedin
Message 7 of 13
hello,
i have done everything that was in your previous reply.
but when i did all the steps and try my block, the count stays at 1.
can you please help me with this.
thanks in advance,
Kevin.
Message 8 of 13
steven-g
Your block works just fine here. Did you do a regen after stretching the block
Message 9 of 13
one more question about a dynamic block: when i do an array in the block, can i do it also for the attributes in the block?
Message 10 of 13
steven-g
Nope, if you try it you'll see it doesn't work, but besides that any attribute within a block has to have a unique tag value or it won't be usable in Autocad.
Message 11 of 13
RBassadone
Hi there,
I've just picked up this tip and tried it on my drawing, but because my block length [distance] is not a whole number, I'm getting an error code when I try to add the Conversion factor.  It's saying 'the conversion factor is invalid'.
What am I doing wrong or is there a way around this?
Message 12 of 13
ojuris
you can do that in 2 ways:
  1. with formulae
  2. with conversion factor
Message 13 of 13
RBassadone
You absolute legend! Amazing, thank you 🐵
