Dynamic 3D Block
Dynamic 3D Block
stacero
Message 1 of 12
Dynamic 3D Block
stacero
Hello everyone,
I have a problem with creating a dynamic 3d block. The problem is the following, I need to create a stretch of the block, normally if the block is rectangular I have no problem, but in this block I have some faces that are curved. I have tried different ways to stretch them, but it always distorts them or simply does not stretch them. Any idea or possible solution will be very welcome.
I attach the block file.
Replies (11)
Message 2 of 12
j.palmeL29YX
Dynamic blocks are designed for 2D only, point.
Sometimes we can outwit AutoCAD. But before we must know what you want to achieve. "Stretch" - in which direction. Show us an example how the block should look after stretching.
Jürgen Palme
Message 3 of 12
Ed__Jobe
I recreated the block with a fully constrained sketch.
Ed
How to post your code.
Message 4 of 12
stacero
Thanks Ed. In fact, I also created a 2d with a similar solution. However, my problem right now is creating it in 3D. And that works similar at least in length.
Message 5 of 12
stacero
The idea is that it works in a similar way to this 3D block. This is a block of a rectangular solid that you can stretch.
In this one I had no problem doing it, but in this one the problem is the curves.
Message 6 of 12
j.palmeL29YX
For demonstrating I use the block which was posted by @Ed__Jobe .
(view in My Videos)
Jürgen Palme
Message 7 of 12
Ed__Jobe
You have to constrain the curves so that they can only vary by their center point. Plus, in your original one, you didn't use curves to define the edges. You used a polyline with a lot of points.
Ed
Message 8 of 12
stacero
Thank you guys!! This solve completely my issue.
Message 9 of 12
Ed__Jobe
I edited it so that you can adjust the Length, Height and Thickness in the Custom Properties panel. Select it to edit the properties.
Ed
Message 10 of 12
j.palmeL29YX
Attached a completely other strategy to drive the dimensions of the Base- (2D) Sketch, here using constraints.
At the block References test_1 you can change beside the Length and Height also the Thickness as shown by @Ed__Jobe and additional the Radius of the arcs too (both in the properties panel).
But that has nothing to do with the main question, how to manipulate 3D objects in Dynamic Blocks. I did that only for fun and to demonstrate the power of dynamic blocks with Parametric constraints, even if the practical use of such dynamic 3D blocks is very limited.
Have fun while testing ...
Jürgen Palme
Message 11 of 12
rsalastopografia
INCREIBLE, ME GUSTARIA APRENDER A REALIZAR AQUEL TIPO DE BLOQUES DINAMICOS CON ESA GEOMETRIA. SALUDOS
Message 12 of 12
j.palmeL29YX
What is your question? At which point do you have problems?
If you're completely new in using constraints (and if your question is related to this) I'd suggest to start a new thread.
Jürgen Palme
