- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm having a REAL sudden problem here. I've developed an extensive library of dynamic blocks for my employer. Each block is made up of sub-blocks, and they're all controlled by visibility states.
I've tried updating all the master block definitions...but when I go through the update process with an existing layout and do an ATTSYNC, ACAD changes ALL the existing blocks back to their default-insertion state!! AWFUL!! How can I stop this from happening?
I've attached a sample conveyor bed layout. You'll see how the attribute tags are clearly NOT where they're supposed to be. Run ATTSYNC and watch how some of the shorter straight beds REVERT to the default-inserted length of 144"!
