Dyanmic divide in dynamic block
Message 1 of 19
Hello all,
I have a drawing of a rail with holes in it.
The holes at the edges are Fixed with fixed length, in the middle the distance between each hole is changing when i change the Length of the rail, but cant pass 40 cm from each outher(the divide needs to be equal between the middle holes)
Any way to make the same calculate with the dynamic block?
In other simple words i need dynamic divine in the dynamic block
Thank you,
Doron 🙂
Edited by request
Discussion_Admin
Replies (18)
Message 2 of 19
akaterr55
Doron,
I'm guessing your block starts with 3 holes totaling 80 units (2 spaces), adds one hole equidistant from 81-120, after 120 units adds another, and so on. Is this correct?
How long, or how many holes is the max in your block?
Could you post a dwg of what you are trying to achieve?
Message 3 of 19
Take a look into the attached.
Message 4 of 19
Thank you for replying
I started to create a block as i wanted but i am stuck right now at 6 holes.
The block need to get to 17 holes total ,between each hole the distance is divided and the max distance cant pass 40 cm(after 40 new hole apper...
I got to 6 holes but then things start to break and not work (dont know why)
Joe Wendy this is the right way but look what happen when i added more holes(no place i think)
Thank you and have great day...
Message 5 of 19
ojuris
hi!
for 6 holes you forgot add correct distance multipliers for stretch actions
I add little bit different block for your problem solution (with red lines)
Regards
Juris
Message 6 of 19
wow thanks...
It will be great also to know how you did it 🙂
The block for some resion is locked and i cant see what actions you did...
On the way if you can correct the distance from end to end(side to side) is 70 first hole is 8 and sec hole is 15
Thank you
Doron
Message 7 of 19
ojuris
I didn't lock block
I just open drawing and block isn't locked - I can open it ...
Message 8 of 19
Its not showing me your actions.
mabey becuas i am using LT?
Message 9 of 19
ojuris
I don't think but I don't know that reason is LT
try open this file (found in forum - use as example for that block)
Message 10 of 19
This what i get when i try to open it..
On the way (if you can) to correct the distnce of the block
Side to side(start to end) =70
First hole =8
sec hole =15
Message 11 of 19
ojuris
correct what you ask
block doesn't have much elements - 1 horizontal constraint parameter, 1 array and some geometric constraints
I think in LT you can see that all but can't make new constraint parameters
Message 12 of 19
Hi
i have a doubt that i havn't seen any array in block editor and also that how you merged those lookup parameter , visibility and a linear parameter together so that when the linear dimension changes it automatically changes to respective visibility page
even you hav enable the grip visibility for linear parameter alone
so if you don't mind could you explain me i try to learn dynamic blocks! but at now i am creating only simple blocks may be if i come to know these kind of solution which lead me to do some complex blocks
Thanks in Advance
Message 13 of 19
ojuris
Look this screencast - I made it for other forum member
I think some things will be clearer
Message 14 of 19
Thankyou!
But there is no visibility i would like to know how you merged those visibilities,lookup parameter and linear parameter together But those  screencast doesn't say that!
 you can see these attachment
here there is no property table,functions,formua's etc but those linear parameter length activates lookup and visibility but i don't know how it works!
could you explain it little more
and if you have any tutorial regarding these kindly share it
Thanks in advance
Message 15 of 19
ojuris
understand what you ask
in that block there are not simple lookup table but double lookup table (1 lookup parameter have 2 lookup tables)
if you can't see - switch BACTIONBARMODE to 0
double lookup table makes them work together
Message 16 of 19
Good Morning
I'm having trouble making this block
I can not increase the box in both directions.
Can someone help me please?
Message 17 of 19
Libbya
The issue with your block does not appear to have anything at all to do with the subject of this thread.  It would be more appropriate to start your own thread.
You have two dimensional constraints.  If you want the block to stretch when you alter the dimensional constraints, then you need all linework constrained so that it MUST stretch when the dimensional constraint value is changed.  Easier would be to use dynamic linear parameters and then add stretch actions to stretch the linework.  If you would like further assistance with your block, post your own thread.
Message 18 of 19
Sorry for the inconvenience.
Message 19 of 19
Libbya
It's not an inconvenience for me this way or that.  My reason for promoting the use of a new thread for a new subject is for the sake of anyone searching for the subject/solution in the future.
