Doubling of dynamic block geometry
I'm finding I have blocks, I've created them with dynamic elements, and I come back to them a day or so later, and the geometry has doubled or tripled. I still have the dynamic component there, but everything is like it has been copied, inside the block?
So a simple block I did for example, a rectangle with something to array (look like plywood), so I could add flexibly to my drawings for length and thickness, I've just found the block worked as it should, but behind what was working was the non-dynamic elements in the block where nothing was stretching.
Nothing was done to the block to make it this way, some glitch in the matrix has just somehow changed to be like this.
I can't say how it is happening; it just is happening. No point in providing examples as a result.
It isn't just the one time, in the one drawing, it keeps happening. In some cases I've found the geometry tripled. I WBlock my dynamic blocks out to a library so I can somewhat manage this, but it is getting annoying.
Wondering if anyone else has come across this.
Using LT 2022, started autocad on R12 in 1995 so not a 'novice error'.
Finding some other really weird things in LT2022 as well, 2 objects, one a copy of the other just rotated 90 degrees, the rotated one wouldn't plot. never seen this kind of behaviour. I can't start drawings from scratch every 5 minutes!
