Double lookup ill-logic
Hello Forum,
It has been a minute since I played with a DL. I believe the logic is complete, AC does not think so...
I cannot change between sizes of gang. Any recommendations would be appreciated or how to trim it down.
Thanks everyone,
Adam
I know you got this @Libbya
Libbya
For diagnosis, make it so the memory rotate parameter values and the double lookup show in properties and are visible for all states.
You will then see that the double lookup goes to 'custom' when the block is failing.  That is because you do not have a row that matches the values.  You are missing a lot of rows of values.
See screencast.  You can see that as I work through and add the appropriate values, the double lookup works until I hit another missing row, etc...  I give up after 10 minutes.
That should get you started on diagnosis/repair, though.
Excellent, thank you for your push!
Ill post it back up...
Boom goes the dynamite!
Block works great now!
Pardon the mess of vis states I first sent. (that was embarrassing)
Thanks for all your help.
Here's the working block!
try to break it
Lastly, I could swear I've done it before, changing the order of the custom properties in the pallet. I would ideally like the floor type first then gang size under that. I changed the order in the parameters manager but didn't move in the prop pallet. May you have any suggestions?
h_s_walker
The problem is your lookup states. They cannot be reordered. They stay in the order you created them. All you need to do is delete those three lookups and recreate them in the order you want.
Or just retitle them and change the parameters in them.
Howard Walker
Left Handed and Proud
