- Mute
- Permalink
- Report
Hello all,
I am having trouble with the dynamic block attached. The visibility for the TV and Outlet is not working when you rotate to 225 degrees. All other angles seem to be working properly.
These are the following actions:
-flip action to toggle visible and invisible for TV and Outlet. (Issue at 225 degrees) Text does not rotate.
-Rotate 360 degrees. (Works)
-The Attribute should rotate automatically depending on the angle, so text is not upside down. (works)
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
