Different visibility name on mouseover to a block
valerica.irimia
valerica.irimia
Hello. I have this problem - I'd had created a block with multiple visibilities, maybe 10. Now with a function (in Acad LT) I can number this different visibilities of this bloc in a drawing, but sometimes I forget the name of visibility displayed...it helps a lot if on a mouseover drag over the block, the system return his visibility name... Thanks in advance for any answer.
h_s_walker
You can't hover over a block and find it's visibility state. HOWEVER if you select the block and if you have the visibility properties set to show you can see it in the properties (CTRL+1) menu. See the image below
Howard Walker
Left Handed and Proud
cadffm
Hi @valerica.irimia
Read more about ROLLOVERTIPS
Command: ROLLOVERTIPS<enter>[F1]
and check out the last link on this help page.
In CUI Editor you can add Dynamic properties to rollovertips for Blockreferences.
(problem)
Look at the last line, this are the visibility name of this blockreferences
Sebastian
valerica.irimia
Thank you, the solution proposed works great! 👌👍
