Message 1 of 10
I'm trying to figure out a way to have a fixed diameter of a circle in a block that I'm using in different scales.
The block is for a smoke detector and the circle is meant to represent it's coverage.
When I select everything and scale it in the block editor the circle diameter doesn't change, however when I then scale it in the model tab the restraint is not working and the circle is scaling with the rest of the content of the block.
I have tried both the blue (?) and yellow (Parametric) dimensional restraint (AutoCAD 2020). Not sure exactly what the difference is.
What am I doing wrong?
