Dynamic Blocks Forum
Data Extraction Table
2 REPLIES 2
IanH5033
339 Views, 2 Replies
I've been experimenting with extracting attribute data from dynamic blocks in 2008 (using the extraction wizard). Everything works fine except, when I insert the table into the drawing some of the cells are blank! It's fine in the previews and also all the data is there if I extract to a spreadsheet. Any ideas?
2 REPLIES 2
akhtar4223
in reply to: IanH5033
Share dwg or some more information to understand your issue.
fkp7057
You can try the " Attout" Attributes out the command, It will extract attributes to in .txt file for the selected blocks.
also, you can open the text file in excel by dragging it in excel. update attributes in excel save it. in import the same .txt file using "attin" command.
Autodesk Customer Advisory Groups
”Boost
