Corner snap on rotation
agbrewster99
agbrewster99
Hi all,
As the subject suggests, I'm attempting to create a 'detail call-out' block to use at my workplace, however, I can't get an element of it to work.
As I rotate the call-out text around the indicating box I want the end of the leader to snap to a corner of the box.
Attached is a basic version of what I'm trying to describe, if someone is able to help solve this issue it would be much appreciated.
Many thanks,
Alfie
ojuris
hi!
I think you don't need flip parameters
you need 1 point parameter with stretch with your double lookup
Libbya
Piece of cake.  See screencast.
Libbya
As ojuris mentioned you can also just use a point/stretch and add it to you output table and change its coordinates accordingly, eliminating the flips.
agbrewster99
Amazing!
Thank you both for your quick response @Libbya @ojuris !
agbrewster99
Okay, I will give this a go and see how I get on! 🙂
