Constraints have no effect on dynamic block properties
mehdi-guida
mehdi-guida
Hi
why constraints have no effect on properties handles ?
how can i solve that?
Thank you
Libbya
You're asking how to make constraints affect dynamic parameter grips?  You can't.
Why don't you use geometric constraints and use their grips?
j.palmeL29YX
Tell us more detailed what you want to do (to achieve).
Jürgen Palme
mehdi-guida
I don’t know any thing about geometric constraints?
could you send me an example or video ?
Thank you
mehdi-guida
I think i misunderstood your mean in your last message. I used geometric constraint for make parallel two lines but if the lines have another action ( for example stretch or scale action) , constraint only affect on lines not on their actions.
j.palmeL29YX
@mehdi-guida wrote:
 I used geometric constraint ... but if the lines have another action constraint only affect on lines not on their actions.
Don't never mix geometric constraints/dimensions with dynamic parameters/actions in a block definiton. To get changeable geometry in a dynamic block use either only the one method (geometric constraints and dimensions) or use only the other method (dynamic parameters and actions). Otherwise you will get unexpected results.
Jürgen Palme
Libbya
I used the wrong word.  I meant to say 'dimensional constraints'.
