Constrain Flip Parameter along Y-Axis.
deepak_fer
deepak_fer
I am new to dynamic blocks and I am already amazed at the vast features it offers.
Currently I need the community help with regards to a block I am working on.
I prepared a block and I applied a flip parameter along the Y axis. However, once am out of block editor, I need to rotate the block by a certain degree (0-90 deg). When I do this, the flip parameter also rotates.
My question : How to constraint the Flip parameter to the Y Axis, such that no matter how I rotate the block, the flip parameter is always parallel to Y Aaxis?
Libbya
Always post the block.  Add descriptions within the block file and the result will be an order of magnitude more useful than posting a pdf.  Probably marginally easier to accomplish also.
If you are talking about rotating the block in model space using the ROTATE command then you're out of luck.  If you are talking about rotating the block with a dynamic rotate parameter and rotate action, then it is easy to accomplish.  Just don't rotate the flip parameter or flip line.
