[Running AutoCAD 2015 on Win7]
Is it possible to give visibility states further "pop-out-menu" visibility state options? (i.e. when you hover over a visibility state option, a second pop-out-menu is available to pick further visibility states for that choice).
Where this is useful, is if you have a set of secondary variables (e.g. open/closed, on/off, hatch/no hatchetc.) that you want to be able to apply to all your primary visibility states (e.g. type, size, etc). This cleans up/ organizes the visibility states list, and means I don't have to create as many visibility states when building the block.
I don't know if this is done solely with visibility states, or if I need to incorporate lookup tables, block property tables, and the like (which I don't know very much about).
Just a note: "visibility-add-eng.lsp." is not what I'm looking for; I don't really want the user(s) to have to pick from different visibility menu icons all over the block.
Any help is much appreciated.
Cheers,
TBOMS
