Combined Visibility States in Dynamic Blocks
Message 1 of 25
[Running AutoCAD 2015 on Win7]
Is it possible to give visibility states further "pop-out-menu" visibility state options? (i.e. when you hover over a visibility state option, a second pop-out-menu is available to pick further visibility states for that choice).
Where this is useful, is if you have a set of secondary variables (e.g. open/closed, on/off, hatch/no hatchetc.) that you want to be able to apply to all your primary visibility states (e.g. type, size, etc). This cleans up/ organizes the visibility states list, and means I don't have to create as many visibility states when building the block.
I don't know if this is done solely with visibility states, or if I need to incorporate lookup tables, block property tables, and the like (which I don't know very much about).
Just a note: "visibility-add-eng.lsp." is not what I'm looking for; I don't really want the user(s) to have to pick from different visibility menu icons all over the block.
Any help is much appreciated.
Cheers,
TBOMS
Replies (24)
Message 21 of 25
bdavisHP8JL
egads I'm am dim!... I had not noticed the down arrow at the far right of the line... thank you so very much!
Message 22 of 25
I was really hoping to see the screen cast that you created for this issue. I can't figure out how to change the value of the individule parameters.
I have been looking for this kind of help.
I am hoping that I don't have to scroll down through 5 door types, 7 door pull types and if there is a cam lock or not.
this will make my life so much easier!
squareknees
Message 23 of 25
Libbya
I have found that an increased number of existing screencasts makes adding new screencasts progressively slower.  To that end, I removed most of the past screencasts and do not have them any longer.  Post up your block and I'll see if I can help.
Message 24 of 25
I have multiple blocks and it would be great if I could combine them into one!
I also have to add another verible to add, a cam lock.
as for the side and the top i won't need to show the lock location.
I also have all of this for the upper cabinets (front, side, and top), tall cabinets (front, side and top), drawer fronts (etc.), and large drawers (same).
If I could do one for each upper, base, tall, drawer fronts, and large drawer fronts. that would be great!
