changing visibility state and layer name
Waseem.MikhaelPLELV
Waseem.MikhaelPLELV
hello everyone,
I have been looking for an answer to solve a minor issue I have with dynamic block.
I have a dynamic block with 10 visibility state, how could I change the visibility with changing the layer as well in same time.
please advise if there's a way of fixing this issue.
see attached.
thank you in advance
h_s_walker
You can't. HOWEVER if you place the block on layer 0, when you turn off the relevant #tag layer the block will "disappear"
Howard Walker
Left Handed and Proud
jtohill
"how could I change the visibility with changing the layer as well in same time.
please advise if there's a way of fixing this issue."
What is the issue you are having? What needs to be fixed?
Waseem.MikhaelPLELV
@jtohill what need to be fixed is that when I choose the visibility state to a certain number same as my cad file
the layer will automatically change as well.
no need to change it manually.
hope I explained it well
jtohill
is there a reason that the block needs to be on the same layer as the revision layer? What if the block was put on layer A-SYMB and you didn't have to worry about it having to be on the correct layer, it's symbol is on the correct layer and when that layer is turned off so is the symbol.
