Dynamic Blocks Forum
Changing Attribute Values from Command Line
3 REPLIES 3
emreakyazicigsl
293 Views, 3 Replies
Hey everyone, I created a bunch of groups and right now my plan is change their attribute values together, in the same time, with one move. Is there a way to change the "Value" of attribute with a code or command or lisp?
Thanks for your help.
3 REPLIES 3
hwalker
in reply to: emreakyazicigsl
If you're using full AutoCAD try the command GATTE which is an express tool and stands for Global ATTribute Editor
Howard Walker
Left Handed and Proud
emreakyazicigsl
in reply to: hwalker
Thanks for your help but I checked after your advice, that's not really what I'm looking for. I got groups like that and my goal is to define a different attribute value for each groups separately. Therefore, changing all the attributes value for a single block is not really I seek. Can you still help?
hwalker
Unfortunately I don't use lisp as I only have LT, but since you have your items in a group and judging from the image they have the same attribute why not just change it in the properties menu?
Howard Walker
Autodesk Customer Advisory Groups
”Boost
