Change text justification on Rotate or Flip
id_11
id_11
Is there a way to do this in a dynamic block:
Change the text justification based on 4 directions. See attached image.
The text is an attribute, so I can't use visibility states.
h_s_walker
No you can't change justification of an attribute on a lookup or flip. However a double lookup can automatically change visibilty states depending on what the angle / flip is.
So all you need to do is set up four visiblity states with the correct justification in each, and set the double lookup to change the state depending on what the angle is
Howard Walker
Left Handed and Proud
id_11
OK thanks for advising.
Can this be done with 1 attribute though? Or do I need 4 attributes.
