Chain parameter with move and rotation
Amriya_Exe
Amriya_Exe
I want to chain move parameter with rotation as shown in image if  I move 10mm this circle left side (0.0mm dimension which will be 10mm.. selected object in rotation parameter will rotate accordingly .
j.palmeL29YX
Please show us an example result how the block should look after moving the circle. (It is not yet clear for me what you want to achieve).
Jürgen Palme
Amriya_Exe
Here is block I made manually The dash lines in GREY showing original position and RED line is result.
I moved that circle 0.0978unit
and rotated rest of objects from center points/base of the block.
In this dynamic block I want to make something like this rotation action on basis of distance I move the circle.
 This is for trial if its work I my original block have many objects that I will select with rotation parameter.
j.palmeL29YX
Even with a lot of question marks in my mind, please test the attached attempt:
Jürgen Palme
Amriya_Exe
yes this is what I have asked for it.
but can you give me some explanation how this works and which parameter to use for better understanding.
j.palmeL29YX
I used constraints (Parametric).
First create a (Sub-)Block (not shown in the video). So you later don't need to add a  lot of constraints between all the rotating objects.
Now create the (Main-)Block, insert the SubBlock and add the needed constraints:
If you have further questions, ask.
Jürgen Palme
