Chain dynamic blocks within blocks
I have a template file that is getting bigger than I'd like. Currently we have a large dynamic block with all of our dynamic detail blocks inside it. All detail blocks have a move grip that does the exact same thing. It adjust the title of the block by some distance 'x', 'y', or 'z'.
The large template block uses a visibility state to change ALL the blocks inside it to the adjusted size. For example, I need to use all the blocks with the text moved distance 'x', so I click that visibility state and explode. This means I have the same assembly block stored three (3, tres, III) times in the large template block.
Is there a better way to move all the text without storing the assembly blocks 3 times. If I could get a chain command to work on the grips without exploding the assembly blocks, that would be great.
All help is appreciated,
TM
