Cannot Create Block
Cannot Create Block
jayhar
Advisor Advisor
Message 1 of 10
Cannot Create Block
jayhar
In This Cad File(attached) I Cannot Create Block.
If Copy All The Drawing & Ctrl+shift+v It Does Not Works
Exporttoautocad, Wblock & Copy To New File I Try It, But Its Not Work
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Replies (9)
Message 2 of 10
h_s_walker
Something in your SDG block is messing it up. I exploded the block and could create a block of all the elements seen.
See the attached drawing
Howard Walker
Left Handed and Proud
Message 3 of 10
jayhar
i need without exploding
Message 4 of 10
vinodkl
First export the drawing to ACAD using "-EXPORTTOAUTOCAD". Now open a blank drawing and using INSERT browse the exported ACAD drawing into the blank drawing.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 10
h_s_walker
Here you go. I recreated your SDG block in a blank drawing and then copied it into the drawing and created the block. It's called test
Howard Walker
Message 6 of 10
Libbya
I imagine that a large part of the problem is that you are drawing almost NINE MILLION UNITS FROM THE ORIGIN!!!  Why?
Message 7 of 10
jayhar
Its big drawing, size 10 mb or more I delete all and selected only specific drawings
Jayhar.M.J
Message 8 of 10
jayhar
Thank you, its a big file include more drawings, so i use comment WBLOCK and selected specific drawing save and  follow as per your instruction. its working
But error is not fixed. Block are created with error.
Jayhar.M.J
Message 9 of 10
h_s_walker
@jayhar Have you checked the block I posted?
Howard Walker
Message 10 of 10
jayhar
Thank you its working
