Can you simplify this dynamic block
nouri.nurhussein
nouri.nurhussein
In this block, I have a relatively long list of sizes, but there are 2 conditions, with or without spreaders (the pink object). As you can see, I made a very long list to do that, but it shouldn't be. Can anyone update the block to have an (on/off) like button that will do that in place of the long list?
Thanks in advance.
Cheers
Nouri
MMcCall402
You could replace the Lookup with a Block Table and then introduce a user parameter to build a menu system that branches.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
MMcCall402
A simple change in the order of the columns in the table will result in a different branching.  The selections will keep branching until they reach a unique row selection.
Mark Mccall
CAD Mangler
Libbya
It looks like the only difference between multiple visibility states is the text.  Using visibility states for text differences is very inefficient.  You can write different text values directly to attributes by using a block properties table or a lookup and field.
nouri.nurhussein
Thank you very much, Mark
This is much more efficient.
This is the first time I have worked on the "block table". The beauty of self-learning 🙂
Cheers
nouri.nurhussein
Hi Again
The block works like a charm, but I have another issue.
When inserting this block into another drawing, I use different options within the dynamic block. Then, I need to make some changes to the original block in the library and go back to redefine; everything goes to the reset state, and then I have to change each block again.
Is there a way to redefine and keep the changes without going into the reset state?
Cheers
Nouri
