Can't move exploded blocks & delconstraints command not available
I've been creating a dynamic block library at work but have encountered various incompatibility problems.
Whilst I have a single seat of AutoCAD 2016 available to me for the creation of the blocks, I have to make the block usable to everyone else who only have a core (oem) version of 2010 available to them at this time.
The problem I'm experiencing is when the blocks have been exploded, the constraints are still active which results in not being able to move the exploded elements of the former block around the drawing. I can get around this on 2016 using the "delconstraints" (DELCON) command, sadly nobody else can do this as DELCON is to recognised in Core version of 2010. The only way (that I've found so far) for them to delete the constraints is to right click on each one in turn & select delete. As you can imagine the time it takes to delete all the constraints manually is defeating the purpose of using the dynamic blocks in the first place.
Does anyone out there know of a command, either built in or more likely a third party downloadable tool, that can stand in for DELCON ??
Whilst I hold out little hope of solving this, any feedback or workaround ideas will be gratefully received.
Alan
