Can I make the value in a Sheet Set Custom Property dynamic?
I typically have a closed polyline around the outside of my project to measure the disturbed area of the project. I then take the area and put it into a Sheet Set Custom Property. I have various text fields across my plan referencing this area so that it can automatically update when I change the value in the Sheet Set Custom Properties. I have to update this number fairly often and want to know if there is some way to have the value in the Sheet Set Custom Properties automatically update so that the fields across my plan also update along with it. I basically want to put a field into a Sheet Set Custom Property, and then have more fields reference that Custom Property.
Libbya
I do not believe that is possible.  I do not think you can even insert a field into a sheet set custom property and if you did manage that I do not think that it would be able to reference a property of an item in a drawing that often would not even be open.
