Please help in Arraying Grid Line when the Block is being Stretched at Fixed Distance which Area needs to be updated Automatically.
Solved by j.palmeL29YX. Go to Solution.
>>Click<< [EDITed]
The stretch action must not include the right grid line, only the right part of the rectangle.
The array action must not include the the right gridline, but the left gridline.
Delete the right grid line.
Jürgen Palme
In Continuation with Previous Comments Suggested,
Further I would like to track and Update the Fields to know each Block Area which is in Model File.
How can I update the Area Fields from individual Block.
I think there are several ways to get what you need, depending on how you want to use the block.
One example:
I added an attribute to assign a name to each Block reference.
A second (invisible) attribute is a field to get the area of the rectangle.
A DataExtraction creates a table with Name of the refence and Area of the rectangle.
You can modify this principle to your needs.
[addendum]:
Which AutoCAD version do you use? Really an old 2007/8/9 (as your attachments are saved)?
Jürgen Palme
Thanks for quick response and Solution,
At the end good solution, But It would be great if you could Explain from Step-1
Jürgen Palme
