Blocks with attributes
brianwclayton1969
Message 1 of 21
brianwclayton1969
I'm creating blocks with attributes, and I have attached a screen shot of the blocks I have problems with. The problems are with TEXT JUSTIFICATION.
All these blocks and text have to scale every time I change the scale of the drawing in model space or using annotative scale. I have gotten other blocks to scale correctly when I'm just "one" attribute, justification works correctly but not when I have multiple attributes.
Replies (20)
Message 21 of 21
Libbya
I guess I forgot to paste the link in my last post.  Go here:
https://knowledge.autodesk.com/community/screencast
Download AutoDesk Screencast and record a screencast of your step-by-step process of creating your tool palette tool from the block.  Then post that screencast and I will very likely be able to point out what you are doing incorrectly.  The number of things you could be doing wrong is infinite and I already posted a screencast showing exactly how to make a tool that works properly.  Without you showing what you are doing, I'm not going to try guess as to which of the infinite number of wrong steps you are taking.
