Block not acting how I want it to
h_s_walker
Mentor Mentor
h_s_walker
OK So what am I doing wrong with this block?
It simply is showing either one, two or three rectangles. Either closed, the left side open, the right side open or both sides open.
Keep the properties window open and you will see what I mean. Selecting any of the states does not do what it's supposed to do EVEN though they show as correct in the properties window
If you're going to edit it please do not put any parameter constraints in and save it in 2010 format as I only have LT2012
Howard Walker
Left Handed and Proud
ojuris
hi!
for double lookup use point parameter, then you even don't need add actions for point parameter
h_s_walker
Perfect. Just what I was looking for.
To do that I was actually following an old post that @Libbya made ages ago
Howard Walker
