Block Editor not closing
jayhar
Advisor Advisor
jayhar
If i open block editor to work, after saving BLOCK EDITOR is closed. But Model space till shows  "Close Block Editor".
Find the attachments
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Vinayv4v
Which version of Autocad are you using?
When does this problem occur?
Does this occur when you close the file still in BEDIT.
Try the following Links
https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2012-block-e...
https://forums.autodesk.com/t5/autocad-forum/redundant-block-editor-toolbars/td-p/3021222?nobounce=
Cheers,
Vinay Vijayakumaran
äcäp
I would think that it's related to the memory issue. Download and install Autocad Service Pack perhaps will fix the problem.
In my workplace, some pc were still using old version of AutoCAD and the same problem keeps coming when user trying to edit a block and save/close the Block Editor. Normally, close the current open drawings and reopen it back will move the Block Editor bar away. That's our temporary solution.
