Block Attribute Not showing In Model Space
ilevy
ilevy
Hi, I just created a dynamic block and everything works fine, even when I test the block it seems to work perfect, but when i save it and go to model space, the attributes just dissapear, I dont know why, hope someone here can help, thank you!!!
Libbya
ATTSYNC command.  Any time you make changes to the attribute definitions, you need to run the ATTSYNC command for those changes to take effect in existing blocks in model space.
ilevy
It worked, thank you Lybbya
Crystal333
Same problem--quick and easy solution.  Thank you!  🙂
