Best way to create Dynamic Block representing culvert
neilyj666
Mentor Mentor
Message 1 of 10
neilyj666
I want to create a dynamic block representing a culvert in plan but which is able to show various standard culvert "diameters". The red line represents a centreline and the blue lines are the plan representation of 2 specific diameters. I want to be able to show the blue lines at 0.60m, 0.75m, 1.2m, 1.5m etc.
I also want to be able to rotate about the mid point of the centreline as well as streching each end equally along the centreline
What is the best way to do this - I'm not very familiar with dynamic blocks apart from adding a Rotation and a Flip
Neil
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (9)
Message 2 of 10
ojuris
try this
Message 3 of 10
neilyj666
That's excellent - I now need to work out how you did it...!!!
Message 4 of 10
Libbya
I would use a polar parameter instead of the separate stretch and rotate.
Message 5 of 10
neilyj666
Thanks for this one as well - I'll look how you did it.
Message 6 of 10
neilyj666
@Libbya and @ojuris I'm a bit lost as to how you got the different width parameters i.e. 600 750 1200 1500 etc into the block definitiion. I've been able to add new ones (300 and 1050) myself but I don't know how to set it up from scratch
Please can you advise me how this is done?
Message 7 of 10
Libbya
Add a linear parameter.  Select the parameter and go to the properties palette.  Under Value Set go to Distance type.  Change it from None to List.  Use the Dist value List to add the appropriate values.
Message 8 of 10
neilyj666
Got the distance sorted but now I can't work out how to get each side to move outwards and maintain the distance correctly
Message 9 of 10
Libbya
Select the parameter and go to properties.  Change base type to Midpoint.  Add two stretch/move actions, one associated with each end of the parameter and stretching/moving the linework at that end of the parameter.
Message 10 of 10
neilyj666
Thanks for the quick response - it seems to be working for me at last....now to the Polar parameter...:)
