I have created a pretty basic block for my company.
every time I insert the block in a scale other then 1/8th all the points move. base point becomes moved so does the attribute and the rotation point..
Attached to this are examples and the block..and the text comes in fine but when I send it to other ppl in the office to use the text is super small instead of scaling to the drawing accordingly. I have added the scales to the block but it still doesn't come in correctly
Does everyone have the same setup in regards to Units on their seats of AutoCAD? (for a start)
INSUNITS
INSUNITSDEFSOURCE
INSUNITSDEFTARGET
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Since I don't do much (any) isometric.
What have you done to affect the Crosshairs on the Pickbox in your files?
And did it make sense to create the DynBlk in something other than World coordinate system? (If that is what you did.)
"...but when I send it to other ppl in the office to use the text is super small instead of scaling to the drawing accordingly."
You threw me off with this statement in your first post.
Is the Block created in World UCS?
I have CANNOSCALE set to 1/4" =1' here and your Block works fine.
Are all the Annotative Scales listed for the porposed scale of the Block?
Have you tried unchecking Match Orientation... of the Text Style?
Do This:
Highlight your Attrib so the Properties Palette is open.
Add all the Annotative Scales needed to the Attrib. This should be the third line under the Text dropdown in the Palette.
