base point can't mirror
Hi There,
I have a block that is working fine until i used the mirror parameter. I can't mirror the base point properly and i don't know what i am missing. I've already used a separate point parameter to move this action but still i can't get thru. I attached the file and hoping to get some hint.
MK
Libbya
The MEM APP point parameter is the issue.  It is not moving with the other MEM points despite the fact that it is correctly added to the Move4 action.  Interestingly enough, this can be solved by making the MEM APP point chained in properties.  I spent a fair amount of time looking at your block and do not see anything that is set up incorrectly and that point parameter should not need to be chained to function correctly.  Definitely strange.
Thank you again Mr. Libbya. I got it, but i'm just wondering how do you pin point the problem. Perhaps i can use it in future time.
MK
Libbya
First I did the flip action and then looked at the double lookup in properties and it showed 'custom' so that made me think it was an issue with the input parameters.  I turned on the grips for the MEM points and saw that the MEM APP did not move when the chained Position2 parameter was flipped (despite it being part of the Move4 selection set).
Thanks for this hint. I can use this technique how to pin point certain problem. It will really help..
MK
