automatically Align a block with line
pmadhwal7
pmadhwal7
I would like to align a block with poly-line with 2 points.
Same as you can use the measure command to put blocks on a line with a patch distance I would like to do the same but the block should snap with 2 points on the line. is there anyone who can help me with this?
h_s_walker
Welcome to the Forums
Edit your block. Find the parameters tab, scroll down until you find the alignment parameter. Place it on whichever line you want aligned.
Now whenever you move the block, if you use the alignment grip it will align with whatever line you select
Howard Walker
Left Handed and Proud
dbroad
What is a "patch distance"?  Are you trying to create a block that is an array?  Picture worth thousand words. 🙂  Post a drawing with what you've attempted and what you want.
Architect, Registered NC, VA, SC, & GA.
pmadhwal7
Patch distance is vary somewhere it will be 10 m somewhere it will be 1m or 2m, block are already created for more detail please check screeshots
dbroad
  1. Add an alignment parameter set at the block insertion point.
  2. Add an array parameter set to allow you to array the block.
Having these two parameters will allow you to place the block automatically aligned and then drag to array your desired number.
Sujan.Maharjan
Here we go. Very easy Smiley Wink
"Revit Lies in the tension between what we want to do and what can be done!"
