AutoCAD 2022 Dynamic Block Resetting Values
sean.avis
Message 1 of 1
sean.avis
I have a block where that consists of 2 parameters (ID & desc),  The parameters are controlled by a block properties table.  I create my list then discover I need an additional item.  This works great except I now want to add visibility states to the block.  This is when everything breaks as you will see in the video.  When I close and save the block with the visibility states parameter added (note; it's not part of the block properties table); every instance of the block resets to the value in the very first column.  A video and a file containing the block are linked to this post.
Replies (0)
