Dynamic Blocks Forum
AutoCAD 2022 - Attribute Visibility Issue
3 REPLIES 3
bthirakul87MVP
454 Views, 3 Replies
I created a CAD Block in AutoCAD 2022 with three Visibility and three Attributes. The plan is to show two of the attributes  in all visibilities while one attribute will only show in one visibility. When I tested out the block the two attributes show up properly; however, the third attribute will not show in the correct visibility or any visibility at all.
I have been able to create blocks with this function/ feature in older versions of AutoCAD (2013, 2018). Is this function no long supported with blocks created in newer versions of AutoCAD?
Attached is the block in question. It was "WBLOCK" from the original file.
3 REPLIES 3
Libbya
in reply to: bthirakul87MVP
Try Lock Position = Yes.  In general attributes need to be locked to cooperate with dynamic functions.  I don't have 2022 to test with.
Thank you. That solved the attribute visibility issue. I'm assuming if I want to move that particular attribute I would need to add a parameter and move action?
Libbya
Exactly.
Autodesk Customer Advisory Groups
”Boost
